thank you coach!
Is there a way to manually mark a workout as ācompleteā without having the workout data load? @Coach_Theia has a long ride added to my schedule and I want my long rides to associate with that ride. But typically I will doing the workout and then just continuing to ride to accomplish the long ride. I would like to mark the workout as complete without merging the long ride to the programmed workout. Not sure if that makes sense, lol
@bkolden click on the workout then the pencil to edit, a window opens, select the āCompletedā tab and enter details. You can enter only time if you want.
Hi Everyone and Anyone! Iām having an issue with Final Surge uploading to Zwift. It has worked in the past as evidenced by previous workouts being there when I open up custom workouts in ZWIFT. Iāve now tried two different sets of workouts - last weeks and this weeks doing the same things Iāve always done:
- Download from FS to my computer
- Cut and paste into my ZWIFT file that holds all the other previous workouts.
Once itās on the ZWIFT rider numbered file, I see the ācloudā and then it disappears letting me know it has downloaded on my computer. When I log into ZWIFT they are not there as custom workouts along side the previous and older files.
Iām wondering if this is a Final Surge issue or if I should be calling APPLE to see if they have actually downloaded. But why they would be in my computer file with 4KBs noted as size of file and then not be there on the app BAFFLES me. Iām looking for any help as I would really like to be doing the current workouts and not just going back to the past onesā¦or not! Thanks for any advice or redirection, a frustrated Kim
@kswhite make sure you are uploading to the Zwift folder and not another folder with your Zwift ID, I have one with my Zwift ID thatās not under zwift so I have to be careful. I also launch Zwift on my laptop after I do that even though I run Zwift on my iPad to ride.
Same was happening to me. I was putting them in the wrong folder. Why there are two Zwift folders
. But one has your Zwift ID. Thatās the one you need to use.
Good luck.
@kswhite I use Zwift on Apple TV, but to access the Final Surge files there, I have to first download the WOs into my Zwift ID folder on my PC, then I have to open and run Zwift on that PC, then close and go to my trainer and start Apple TV. The WOs are then available. If I forget to run Zwift on my PC after adding the files, they wonāt show up on the Apple TV. It takes a while to get all this done (10 mins), but usually I remember to do it on Mondays so that the entire week is ready on the ATV. (I have forgotten a couple of times, and due to time restraint Iāve had to just do a random ride instead.)
@nina have you tried doing the workout in āfree modeā? Pick a course and just follow the intervals from final surge by looking at the FS app on your phone. Iāve been doing workouts this way for 7 years now. It takes some getting used to at the beginning, but then itās super easy. The workouts follow a very predictable format and the main set is typically reps of one interval type.
@nina you can always write out the WO or load it to your bike computer, that may be less effort - i wanted to free ride it yesterday so i just pushed it to my wahoo roam and followed it there - thatās what I do when Iām traveling and have to use a gym bike.
@PaleGail how do you do that?
@Coach_Theia Yes, Iāve done that a couple of times too
If the workout is hard, itās difficult! Iāve also switched around a bit on the week instead, doing the Wed free ride with tempo if downloadingās been forgotten before Tuesday, for instance.
Now that itās summer I ride outdoors every time the weather permits, and following a WO then is just impossible when I donāt have a power meter for my outdoor bikes.
@PaleGail I donāt have a bike computer, only the Garmin watch. But following the WO in FS works okayish, I just canāt be bothered sometimes, I want the Zwift countdown and āsame procedure as alwaysā ![]()
And once completed, the workout uploads automatically to Final Surge. @Gossimrr
Connect Final Surge to Wahoo
- Log in to Final Surge: Go to the Final Surge website or open the Final Surge app and log in to your account.
- Connect to Wahoo:
- Navigate to the āSettingsā or āAccountā section in Final Surge.
- Look for the āIntegrationsā or āConnected Servicesā option.
- Find and select Wahoo, then follow the prompts to authorize and link your Final Surge account with your Wahoo account.
Sync Workouts
- Plan and Save Workouts: Ensure the workout you want to download is saved in your Final Surge calendar.
- Sync Workouts:
- Open the Wahoo ELEMNT Companion App on your smartphone.
- Go to the āWorkoutā tab or section within the app.
- Tap on āPlanned Workoutsā to see the workouts imported from Final Surge.
Download Workout to Wahoo Bike Computer
- Open the Wahoo ELEMNT Companion App: Ensure your bike computer is turned on and connected to your smartphone.
- Navigate to Workouts:
- In the Wahoo ELEMNT Companion App, find the specific workout you want to download from the list of planned workouts.
- Download to Device:
- Select the workout, and you should see an option to send or sync it to your Wahoo bike computer.
- The workout should now appear on your Wahoo bike computer under the āPlanned Workoutsā section.
Execute the Workout
- Select the Workout: On your Wahoo bike computer, navigate to the āPlanned Workoutsā section.
- Start the Workout:
- Select the synced workout from Final Surge.
- Follow the prompts to start the workout.
The only thing thatās a pain is i have it set up for my āridesā to cross to FS from strava and they do from wahoo both so when i rode Fri and did the WO , i had t delete a couple one FS so it didnāt duplicate - but thatās easier than downloading from FS, uploading to Zwift, etc.
Thank you all. @Nina - I do too, so this is the added bonus info, THANK YOU! @PaleGail @Gossimrr - I played on my computer last night and found MORE than one file with my rider number. So, I dumped them in all LOL. Just back to my computer now and fired up ZWIFT and there they are in all their glory. Rode outside today ( road) and yesterday (gravel) and it was a real treat. Not hot, slightly overcast blue sky. I thought of you @Gossimrr as I wore my NYC Velo jersey
My hubby is training for an Olympic size triathlon in September, so I have a very motivated riding buddy. Itās so nice because I still donāt have a group to rie with here yet. And @Coach_Theia - perfect way to integrate the FS workouts! #noexcuses ![]()
@bkolden this post explains everything in detail, including all the answers to your questions:
Oh no @bkolden !! I connected everything between FS and Zwift late Tues night and when I was checking things last eveing, i noticed that the Thurs WO had not transferred so i did it the old way. I did miss doing this in the picture and I tried the manual push from the FS event (three dots, push to Zwift) which didnāt seem to work either - but the Sat WO is there
It says it sends the next 4 days WO every evening - i guess weāll just have to see how it goes but even if 1 goes without the extra steps its a good day at least to me
@PaleGail I too didnāt see this step. Iāll see whatās what next week. I checked in FS and it says itās connected. I guess if it doesnāt work I can always disconnect and reconnect.
